STILLEN HFC Installed Video
suby01
Car: 2007 Infiniti G35x
just got off the phonizzle with stillen. and they will be sending me new sensor spacers they called them that clears the code and helps it breath. he said could be same produciton G or Z and some will give a code and some wont makes no sense but w.e will update once installed.
4drsleeper
Car: 2008 G35
Thanks for all the info guys. I want to keep this thread alive because I'm looking a buying the HFC soon also.
However, I have two main concerns:
1. I want to make sure that there is no problem with the CEL...which you guys are testing now.
2. I was looking for something that sounds stock during normal driving.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
i think HFC's are always going to have a more throaty sound than stock....regardless of which brand you get.
I wanted to get the Kinetix but got nobody else who wanted to get in on the deal
suby01
if you change out the exhaust in any way there is no way your going to have a stock sound.i think mine sounds awesome. and for cel just get o2 spacers
4drsleeper
Car: 2008 G35
suby01 wrote:if you change out the exhaust in any way there is no way your going to have a stock sound.i think mine sounds awesome. and for cel just get o2 spacers
So, can I expect the car to sound very close to stock at idle and low RPM's or is there a definite difference?
Also, did your o2 spacers fix the CEL?
tollboothwilley
02 spacers fix the CEL
and you will have a slightly different sound at idle, but its not much different. Especially from inside the car. ~3000 rpms is where it really wakes up.
suby01
exactly rev your car up and listen to my video thats what youll get when i rev it to low rpm's when i floor it you can hear the intake too.
