STILLEN HEADERS FOR 2007 ALTIMA 2.5S SEDAN
General discussion area for the L32-chassis Altima
el_blacky06
Car: 2007 Nissan Altima Sedan 2.5s 6MT
I WAZ CONTACTED BY KENNY FROM STILLEN WENDESDAY DAT HEADERS FOR THE ALTIMA 2.5S WERE COMPLETED FOR THE SEDAN IT COMES CERAMIC WITH AN ADAPTER THE THE CONNECTION FOR THE CATBACK. INSTALLATION TAKES ABOUT AN HR TO COMPLETE IF U FOLLOW PROCEDURES CORRECTLY. ANY INFO OR HELP U COULD CONTACT ME
gatorglaze
Car: 08 Nissan Altima Sedan
Ummmm......Thanks for the news!!!
noshift
Car: 07 altima
me and a buddy did the install one mine and the instructions say that, unless i am reading wrong, that there should be 3 O2 sensors. im not sure if the 07's are different but i could only find 2. anyone that has the headers for the sedan, can you help out with this? where does the bung plug need to be? thanks guys.
el_blacky06
well as far as i could see myself theres only 1 sensor dat could go to the adapter but since i have a custom made exhaust without cat it wazant necessary for me to use it. i believe the kit comes with a bolt to cover one of the holes on the adapter try to use it and see if it helps. and for people with custom downpipes use a flexible because the backpressure would most likely damage the piping and most likely snap off
noshift
Car: 07 altima
el_blacky06 wrote:well as far as i could see myself theres only 1 sensor dat could go to the adapter but since i have a custom made exhaust without cat it wazant necessary for me to use it. i believe the kit comes with a bolt to cover one of the holes on the adapter try to use it and see if it helps. and for people with custom downpipes use a flexible because the backpressure would most likely damage the piping and most likely snap off
are you planning on buying the headers? if you do let me know how the install goes. i think we have the problem figured out. thanks for your help.
el_blacky06
MY HEADERS HAVE BEEN INSTALLED B 4 I POSTED THE BULLETIN AND LIKE ALWAYZ I RAN INTO A FEW PROBLEMS BUT I GOT IT WORKED OUT
unknow
Car: 2008 Altima Sedan 2.5 S CVT
el_blacky06 : Did you get SES Light when you removed the cat? Did you reallocate the O2 senser?
Cuz I'm going to do custom exhaust this week direct from header till the end and I'm planning to remove the cat, but I don't want to get SES light.?
noshift
Car: 07 altima
what kind of problems did you run into?
el_blacky06
i tried putting a downpipe without the sensor and dat caused the ses light to turn on. with dat happening u gotta make a hole custom made by a welder and once the sensoris on then it should go off
el_blacky06
noshift wrote:what kind of problems did you run into?
el_blacky06
just the sensor problem and another thing is the headers it turns out after u tighen the bolls theres a small gap between the headers and the downpipe so it causes a ratling noise when u step on the gas so it needs a gasket to cover the gap
unknow
el_blacky06 wrote:i tried putting a downpipe without the sensor and dat caused the ses light to turn on. with dat happening u gotta make a hole custom made by a welder and once the sensoris on then it should go off
Thanks man for the information I will try to get the custom exhuast asap :>:>:>
Another question Did feel so much improvement in the performance when you made the custom exhaust without the cat?
noshift
Car: 07 altima
el_blacky06 wrote:just the sensor problem and another thing is the headers it turns out after u tighen the bolls theres a small gap between the headers and the downpipe so it causes a ratling noise when u step on the gas so it needs a gasket to cover the gap
what did you about the sensor issue? did you have to many bung holes?
el_blacky06
the sensor i placed it at the same spot where it belongs in the cat. on the downpipe make a custom hole for mine it waz made by a welder itz very easy to make
el_blacky06
itz not much improvement maybe at the most 5hp for the downpipe plus another 8 to 10hp for the exhaust. the good thing is itz a bit more gain and u could backfire which is cool for me
el_blacky06
Return to “4th Generation Altima Sedan (2007-2012)”
