stillen grounding kit out today is it worth it 08 altima coupe
All things Altima Coupe.
altima5507
Car: 2008 altima coupe 3.5
does the grounding kit really work help me out wanna buy that if it does and does anyone have a full list of parts and sites available for the altima coupe
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
The site that has them all is the one you are at!
What are you looking for, we can help you find it... use the search button, or look in the appropriate categories for more info.
I have a grounding kit, I think its worth it... Stillen or SentientByDesign, they are both quality.
Some may say they arent "worth it" but thats up to you!
TameRacingDriver
Car: Nissan Altima Coupe 3.5
From what I have read, yes, the grounding kit works and is good for 2-5 whp (usually 2-3whp). In the end, I would go for the larger power gainers first. Cat back, intake, y-pipe, aluminum pulley, ecu retune, then the small power gainers (new plugs, grounding kit, etc.) as you run out of things to upgrade.
altima5507
about those the ecu and ypipe where can i get the retune and when will the y pipe be out i so far have injen short ram and custom magnaflow catback pipe eibach springs and 20x10 enkei ls-5 black
mikegtr06
Car: 1995 180sx
you can get the bully dog tuner...... and you have 20 x 10 all around ????
and as far as i know there is no release date as of now on the y-pipe.
altima5507
how do i put pics on i have them but on my facebook yes 20x10 all around but you need to stretch the tire to make them fit go with a 265 30 r20 if you have facebook add me its stavros georgiou from north jersey palisades park i got like 50 pics of the car need some idea though and have some pretty sick ones(altima coupe and rogue share same chassis imagine an awd altima coupe baby gtr)
mikegtr06
Car: 1995 180sx
use photobucket.com and upload your pics there....
mikegtr06
Car: 1995 180sx
altima5507 wrote:have some pretty sick ones(altima coupe and rogue share same chassis imagine an awd altima coupe baby gtr)
http://forums.altimas.org/zerothread?id=399457
simpsons did it.....
altima5507
TameRacingDriver
Y-Pipe from http://www.racingline.com good for 13whp prototype completed, production do for this time next month.
ECU retune from Technosquare...there are some issues here. He has Beatriz's ECU to tune, but has not responded to her (his?) e-mail as to what the status is. Was supposed to be done end of March or beginning of April. Technosquare definitely has a deserved following, but are hold to get a hold of unless you roll over there (Cali.). They have results of at least 15 whp on stock cars for most Nissan models while staying in the safe range of running. With each additional performance item, that number increases. Check them out with a quick google search. Just an FYI, there site isn't that refined.
Someone already mention the Triple Dog GT Tuner due out this summer. It will eliminate the rev/speed limiter, but there is some question as to whether or not we can adjust the air/fuel ratio. That adjustment is what will free up the ponies from the air intake and everything else. Our cars run rich now. I haven't been able to determine myself as whether or not we can adjust it with this tuner.
altima5507
bullydog tuner is available at summitracing.com right now cant wait for the ypipe
07calsonic
Car: 2007 Nissan Altima 3.5 SE
how does a grounding kit help gain horsepower? isnt just grounding more things?
07calsonic
^ never mind i read stillens artical
FGFCacoupe
Car: Super Black 2008 Nissan Altima Coupe 3.5 SE
Can you post more pictures from the back of the car so I can get a good look at the width of the rear tires. So your 20x10 all the way around, with 265/30/20 on all four wheels? Definately post those pics for me asap if you can.
altima5507
dont have one like that let me clean it up this weekend after i do a couple new things to it and paint a few things and ill snap some new pics hopefully next weekend
altima5507
ok this is odd just read up on the wheels technically there not 20x10 but 20x9.75 but market by enkei as ten for better sale and yes its that all around had thicker tires but when we lowered it it rubbed on the fender
FGFCacoupe
I appreciate it, please just get them up as soon as possible, even if they arent the best quality. So what did you do to fix the rubbing, did you drop to a smaller size tire, or what? I appreciate it again
