Rob.Vegan »
https://forums.nicoclub.com/rob-vegan-u101073.html
Wed Apr 01, 2009 3:31 pm
Sorry to see the coupe like that man, however the fascia fits very snug. As long as you take your time and follow the directions everything will come out perfect. You might want to have someone help out though just to make sure everything is even and you're not dropping the piece.
Only problem I had with it is the two little things in the middle on the bottom were sagging a little bit, but that's either because I put the tape in the wrong spot or it just didn't hold I'm not sure. All is fixed now though
