Stillen fascia fitment problem
All things Altima Coupe.
dkgordon
Car: Nissan Titan
I'm currently in Iraq so I can't show pictures. The part of the fascia that is just under the fenders and behind the headlights keep popping out. I can push it back in but every time I drive the car on the Interstate, when I get home, it's popped out again. Has anyone had this problem? I know since I'm in Iraq that I can't even fix it right now but I've been browseing all over this site and figured since it bothered me....I'd ask. Thanks for any help.
l33th41
Car: 2010 Nissan 370Z
2010 Mazda 3
adidas2go wrote:Same thing with mine. I drilled holes on the inside lip of the fascia (where the top and bottom bolt together) and tied zip ties to the frame, pulling in the corners to the correct sitting point
dkgordon
Car: Nissan Titan
Since that mentions where the top and bottom bolt together, I don't think this is what I'm talking about. Since you used adidas's post, I used his car for a little pic (Hope you don't mind adidas). Hopefully this picture explains better. The red line is where my bumper popps out...
Ok, I thought insert image would let me insert an image on my computer but that didn't work. I remember people talking about not knowing how to and that includes me. I tried to search it but that didn't help.
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
YUP, i have the same problem too! I've even gone to the pint of replacing the clips that the fender slides into and supposedly lock into place. Adidas said he drilled a hole where the two bolt together and from underneath the car (you'll have to take off the plastics) zipped tied it to the frame.
In short, your fascia is working as designed
Hopefully Kyle will read this and get us resolution to the problem.
dkgordon
Car: Nissan Titan
Ok, I think I have an idea of what you're talking about. I'll have to wait of course and look inside the fender/ up the fascia from under. Thanks
