shift_mikey wrote:So my stillen developed a little bit of a squeak due to it slightly rubbing on the rear black molded piece on the rear bumper, so i decided i'd make my final adjustments (which i hadn't done yet)
I just pulled into the shop at work, loosened all the clamps, and went to work. I tapped on the Y pipe (hitting towards the engine) and drove all the pipes a little bit further together. That gave me the clearance i needed on the rear bumper.
I then twisted and moved the long rear section and the y pipe along with the mufflers to position the rear flange a little better. I realized that the left muffler would not sit straight in the bumper cut out unless i moved it in a fashion that made it crooked. The pipe was a little too long. I removed the Y pipe, i cut 1/2" off of it, and reassembled.
With my new adjustments, and lining everything back up, i achieved a PERFECT setting. My pipes are even (from the back, both cans are tilted ever so slightly to the outsides of the car), my tips are even, and are centered in the bumper outlets.
Perfecto!!!!
