Stillen blower-fuel pump won't PUMP!!
craizg35
Car: 2003 infinity g35
This is my first stab at a forum so I hope this works! I just finished putting a Stillen stage 3 blower on my 03 G35. Install was fairly easy . I've also put on the Stillen cold air intake and an HKS hi-pwr cat back exhaust. After we got done with the blower and turned the key...nothing at the fuel pump. I've jumpered the pump and it works. I've bench checked the 5 or 6 little relays on the passenger side firewall...they all checked O.K. (out of the car). I think I'm getting power back to the pump, but I don't know which pins are supposed to have power at which time. I've triple checked the wiring I did for the Stillen computer..all O.K. . I've also tried a few other things but don't want to bore the sheeot out of you. I need some good ideas please.
kmech_7
Car: 2003 Infiniti G35 coupe (Skyline) Vortech Supercharged Jul 08 ROTM
Have you checked to make sure that the point you are Grounding to is a sufficiant ground point?...make sure to clean the area it grounds to also. If this doesnt work you can give me a call. my number is in my profile.
