tmonttt wrote:i had a similar problem is it trying to turn over?
It's not trying to turn over because it can't.
I have 3 different starters for it now. And I bench tested all 3 at work and they all failed for some reason. They all have enough power (as in amperage is sufficient) but the starter gear that spins the flywheel does not get ejected.I am getting fuel cause I can hear my fuel pump prime and I put in a new Z32 fuel filter. And no, I never saw any red eye on the ECU. I probably will replace the starter relay, but I can hear the starter relay clicking everytime I go to try to start the thing, so I don't think the relay can really be the issue.
I am considering using my KA starter and put the guts of it into the SR one, has anyone ever done this before? I would be using the starter off the KADE... I used the search button and found a couple but the pictures that are matched to the words are confusing a little bit. I am not sure which parts I am switching out exactly. Oh well, might as well and just take the thing apart and start tinkering.
If anyone might have any ideas as to why 3 starters would all bench test bad let me know, because the 2 I bought were supposedly good on the other red tops they came off of. Plus they also failed when I had them on the car AND when I used a push button on them. The push button made the little starter gear turn, but never go out to connect with the flywheel.
ARGH! This is the only thing keeping me from having a running car again...
