rb250sx »
https://forums.nicoclub.com/rb250sx-u8777.html
Sun Jun 05, 2005 5:04 am
yah, pressurized from the maf all the way back, have continuity in all wires. I got the car running again, changing the fpr put way too much fuel in the cyl and fouled out my plugs. So now that the car runs again, i went out and tested the voltages going to the ecu from the MAF. the FSM says ignition on it should be .3V i got 2.63V, cranking should be 1V, i got 2.59V, and idling should be 1.1V, i got 2.47V. I tested the voltages with both the MAFs i have and go approx the same numbers. the maf ground to the ecu is good, and i took those voltages right off pin 27 as well as right where my wires come out of the sheilding. One thing im curious about though, there are 3 wires on the maf plug, 2 go into the sheilding and the other (power) runs outside of the sheilding. when i pull the sheilding apart at the end closest to the ecu, there are the 2 wires and also an uninsulated wire that continues to run to what appears to be a grounding connection down by the ecu. Does this have something to do with the sheilding? I dont know if the increase in voltage is from poor sheilding or what, but it seems strange that i would have 2 bad MAFs that give me the same voltage. btw, i get 12V to the MAF, i know there was a discussion about being 5v or 12v earlier.
