KATwo40 »
https://forums.nicoclub.com/katwo40-u25350.html
Sat Aug 26, 2006 2:37 am
As ya'll know, I'm workin' up a fully built KADE, but I'm currently running the old 200k mile engine into the groun with a T3/T04E @ 8psi.
During this build-up process, I've been installing various parts that will be necessary for the built setup (400whp goal) to keep the downtime at a mininum. This way, it will be simply a removal and installation, rather than removal, re-do stuff, install new stuff in the bay, install engine.
Anyhow, to the point...
Yesterday I installed a Greddy Type-R (Standard spring) BOV on the hot side, right at the intercooler. I have the spring at the softest setting (adjusting bolt barely touching the spring plate) and I can hear the valve opening a little on light pulls, but on a hard pull I can't hear it open, resulting in some NASTY compressor surge (that high pitched pppffwwhiirriirirriirrirrr).
Is this characteristic of the Type-R valve? Will it open fully on higher boost levels (12psi daily, 20psi strip) and stay open long enough to kill the surge?
Anyone with some knowledge on this valve, please let me know if I've chosen the wrong part for my application.
Thanks in advance.
