89'ClubK's »
https://forums.nicoclub.com/89-clubk-s-u38539.html
Sun May 07, 2006 2:56 pm
For a couple weeks my car will smoke a bit at idle. The smoke is white, and has a slight smell of oil. However, it does not smoke at every stop light. Only every 5 minutes or so (off and on). I had a bit of oil in my turbo intake, so I installed a catch can. The turbo has no shaft play and I believe the seals are good (it doesn't smoke on boost or normal throttle). I was told it could be a modulator valve, but my auto-trans doesn't have one. I have good compression, so I would think my head gasket is fine. Coolant smokes white, correct?Out of options, any help is greatly appriciated!Thanks!Patrick Edwards
