I still don't know all the ins and outs, but injector latency is entirely dependant on the injector's, I guess you could say brand, but it is not necessarily related to their size. It's mostly for smoothing out your AF ratios at idle and has less bearing on the engine when it's revving out. If you google you might be able to find the latency of your specific injectors somewhere.
When it comes to TTPMax and TTPMin the CA .adr file with Rom Editor is whacked. They're actually two 1x8 tables that it accidentally combines into one 1x16.
TTPMax = 72, 72, 72, 72, 80, 80, 88, 88TTPMin = 179, 179, 179, 179, 179, 154, 154, 154
TP Limit is your boost cut. I'd leave that alone for now.
What you want to adjust, on top of your K, is the TP Scale (the series of numbers along the x-axis of your fuel/ignition tables. You adjust those by the same percentage as the injectors. I've heard of some people's cars running better without adjusting the TP Scales but generally it seems like the thing to do is adjust them. Try both ways, see how it likes it.
Definately get those codes cleared up though. It's tough trying to diagnose a car while you're also trying to tune something properly. You're never really certain what's causing the problem. It's why I sold my old engine setup (besides bad rings), I wanted to start from scratch and build/tune it progressively.
If you can I'd strongly recommend going back to stock injectors, get everything sorted, then set to work on tuning it.
**Edit:
http://cherrypicker.tripod.com/id10.htmlAn invaluable resource. Pertains specifically to 300ZX's but the concepts are all the same.
