seabee wrote:well you know a car will over heat if the thermostat is stuck open just takes forever for it to heat up but now that you metnion the thermostat being partially closed makes sense to its at the shop now well see what he has to say
A tstat being stuck open will never be the cause of an overheat. For an engine to properly cool itself their needs to be a proper flow of coolant through the engine to the radiator and back. If the tstat is open you will achieve that goal. Closed or partially closed will hamper that effort.
Other things that might prevent proper cooling flow would be: Clogged radiator, faulty water pump, air in the coolant lines, clogged coolant lines.
Also, a blown head gasket can lead to issues that will cause an overheat.
I agree with your first post when you mention that a bad radiator cap may be the problem. Try getting a new one. You don't need the 1.3bar.. a standard 1.1 bar will be just fine. Give that a shot.
