GraySilvia wrote:I'm not sure if anyone has mentioned this or not, but did you switch the temp sending unit to the stock one from your KA? When I did my swap, i was getting high temps on the gauge too, and the rad was cool, engine was warm, just turned out to be i left the SR sending unit in....
JDM240SXDET wrote:YOUR CARS NOT OVERHEATING. I HAD THE SAME PROBLEM WHEN I FIRST INSTALLED MY MOTOR. TRY REPLACING THE WATER TEMP SONSOR WITH A NEW 95 SER SENSOR. THIS SHOULD WORK FINE.
