s10cky »
https://forums.nicoclub.com/s10cky-u37674.html
Fri Jul 14, 2006 10:15 am
allright guys. i replaced my radiator on my 92 coupe, the water pump, the radiator hoses, and the cap. the car continued to overheat, so the gauge said. then I said it must be the head, or the gasket. so I replaced it, didnt even look bad. but replaced it. got the head pressure tested and everything was fine. started the car up and it still overheated, so the gauge said. finally I bought both temp sensors, and it read the same. the wierd thing is after 10 minutes of driving or so, the coolant system doesnt build much pressure. I can take the rad. cap off the rad. when running for a while and i wont blow coolant all over me.
problem #2 is you can hear the valve ticking loud now. I dont understand.\
problem #3 the car idles roughly....
any thoughts?
