Oh yeah? Right on. Good luck with that.fairglen21 wrote: That can't be the problem.
Yes, you should definitely install new aftermarket parts when your engine isn't even running correctly.fairglen21 wrote:Well I took the battery to get it tested and it tested with only 8.9 c.c. amps. So the battery was definitely bad. Also it was a diehard so I wanted to replace it anyways. I am going to install it tonight and then let you know. I am also installing a MSD Blaster 2 setup so that should help as well.
this sarcasm doesn't make any logical sense…even if he had replaced the faulty part with OEM instead of aftermarket to fix the problem……if he knew at a later date he wanted to install an aftermarket upgrade of that part, why wouldn't he just buy the aftermarket part first that way he is saving some $$$? worst case scenario he just takes that aftermarket part and installs it in a new engine if he decides to dump the old one.zachattack_5491 wrote:Yes, you should definitely install new aftermarket parts when your engine isn't even running correctly.fairglen21 wrote:Well I took the battery to get it tested and it tested with only 8.9 c.c. amps. So the battery was definitely bad. Also it was a diehard so I wanted to replace it anyways. I am going to install it tonight and then let you know. I am also installing a MSD Blaster 2 setup so that should help as well.
+1zachattack_5491 wrote:Well, you can take that advice how ever you want. A blaster 2 setup isn't really a small upgrade. You are introducing a new variable into the equation and possibly further complicating the situation. The OP came here for advice, so there it is. I recommend checking components one by one, and not adding new parts.
i agree that everyone is trying to help him, my point was people (like yourself) can suggest things and try to help without being sarcastic or flame him. the man just wants to get his car running and he assumes this forum has people on it that have more knowledge than him and may be able to help him. i think that can happen without giving him a hard time.nvrplzd240 wrote:+1
How many times does the installation of an aftermarket performance part go 100% from the get go, first time plugging it up? I don't know about you but i have a pretty good track record of things needing tweaking to get exactly right after install. All zach was saying was that you just potentially introduced another factor as to why the car isnt running.
oh and dude.. cut out this internet sarcasm s***.. it doesn't work. everyone's trying to help you here
like i said before, the goal is to get the car running and everyone on this forum (at least i hope) would love to hear another 240 is on the road rather than a junk yard.fairglen21 wrote:Okay thanks, I will be picking up a new battery tomorrow.
