Here is a more detailed explanation on why I beleive what I do. Just so I am up front and get my tone across, I am not here to argue I am here to share my experiences so others may benefit and to be taught something myself hopefully.Bluefire wrote:
Maybe my comment was a little too black and white. In the case where you have a very large leak it will affect revs. But if you have a leak this big anyways, it should be very noticeable.
Anyways I responded the way I did because of the countless SR's and RB's that I have seen with rev problems. And the number 1 culprit is improper wiring. The maf itself, turbo or wastegate are really the last culprit.
I was actually wondering if you guys were on the same page as the threadstarter. To me, a car consistently cutting out at a certain rpm is a maf problem. And obviously the car isn't going to make boost since its cutting out at 2k without load.
by the way cursedGTR, I would really like a more detailed explanation of why you believe a turbo motor requires its turbo to run properly other than the lack of boost
-Bluefire
Turbocharged motors are not naturally aspirated motors and get their intake charge from the turbines spooling. Even at idle we can all agree that a turbo spins at a certain speed in orer to make the required pressure for the engine to run. Once you put the engine under positive boost or you start building pressure in your pipes and the pressure leaks out you will have revving problems. Then you are dealing with a lack of air to go with the specified amount of fuel in your fuel map. Fix the leak, fix the problem. I have seen bad MAF's cause all kinds of problems as well, but our main problem here is the actual sensor going bad and causing us to have to replace it (mainly on R32 motors where they are a bit older). Typically on my RB25DET I moved into the positive boost realm at about 2500 RPM that is where I transitioned from Vacuum to boost every once in a while because of the heat and climate conditions here, a grommet would dry rott a little and cause a boost leak (usually cracked at the part where it went from 70-90mm), thus preventing me from going above 2.5K RPM. Also take a turbo car and remove a hose clamp from the intercooler piping and then go drive it around and see how it works for you, I guarantee it won't work very well at all.
I am not saying a motor will not start and run without boost. I am saying that it will not run properly when loaded (i.e. moving the weight of the car) mainly because the turbines will not be putting the amount of air they need to be into the intake manifold.
Also, I did overlook the fact that RB and SR's are nothing but swaps in the U.S. so I am sure you guys come across your fair share of F'ed up wiring.
