Spinn3r »
https://forums.nicoclub.com/spinn3r-u100644.html
Mon Sep 22, 2008 4:37 am
ok short story guys, the car was blowing some blue smoke, so I Replaced head gasket with cometic, (head gasket was messed up) and i did smell some coolant before with oil, now I smell oil. head was inspected, and cut by machine shop a bit just so it was streight, after putting everythig back, replaced with new arp head studs of course, started the car, runs fine, but nothing changed, still blue smoke as it was before, yes i did drive the car for 30min jus tto make sure everything goes out!, motor is fully built rods/cams/pistons/studs/bored,
the only thing i can think of it is oil rings on pistons.. :-/ we did inspect piston walls everything did look normal. IF i knew i would pull the piston out ((
any ideas?
