the camshaft position sensor (CMP) is on the distributor. It has the larger plug that has 4 wires coming from it. With the notch of the harness up top and the two empty spots on the left side of the harness, the wires from left to right are: 180 degree signal1 degree signalbattery voltage ground
The crankshaft position sensor is located above the transmission where it bolts up to the engine. It is near the EGR valve. Looking at the harness from the terminal side with the notch up top, the wires are:Signalgroundbattery voltage
Test accordingly. If you have questions, feel free to email me.
*I got this info from my 95 240sx KA24DE factory service manual. The harnesses may be different from yours, but I doubt it.
BTW, get to finding the problem now, I'd like to see you at the BBQ.
