still no sound throught teh speakers. HELP!
Post all your Nissan electronics, car audio and stereo questions here!
GrilledCheese33
Car: 2008 Nissan Xterra
1972 Yamaha R5
2017 Sea Doo Spark Trixx
So I hooked in my new sony unit and no sound. I then bypassed the amps and still no sound. What have I done wrong here?
Simmsled
Car: TSI GTI - E46 325i
Is your wiring harness connected properly? Sometimes the ground wire on the harness is inadequate for proper grounding. I would try grounding the headunit to a screw somewhere behind the headunit. Do the lights and everything come on? Plays tracks?
GrilledCheese33
1972 Yamaha R5
^yes, all illumination and functions work as they should, I just have no sound w/ the sony unit. I put the factory deck back in and it works, just very quiet b/c of the bypassed amps. Could my sony deck be bad? I have it grounded to the harness adapter, should I ground to something else? Thanks.
0wn3r
Car: 1997 Nissan 240sx SE track car (SR20DET, caged)
check ground, check wires to make sure they are where they should be...
you could do one speaker at a time too... plug it in and if it doesn't work right try reversing them.
also, make sure you're not listening to the radio and also that the volume is actually up
GrilledCheese33
1972 Yamaha R5
headunit was bad. I went and bought another sony from wal-mart and hooked it up to my adapter and all was well. I am gonna take it back to wal-mart and I will hopefully get my money back for the first sony I bought. Then I am going to best buy and purchasing a nice, quality headunit and speakers and amp, and I may have them install it since some of my wiring is screwed over due to my amp bypass. I hooked them back up and all I keep doing is blowing fuses
0wn3r
GrilledCheese33 wrote:Then I am going to best buy and purchasing a nice, quality headunit and speakers and amp
Those 2 don't really go hand in hand... but good luck.
phuphyter
Car: 2002 Infinity G20
how did you bypass the amps? try connecting the speakers directly to the head unit with speaker wire if you havent tried that already
