BCC93QT »
https://forums.nicoclub.com/bcc93qt-u89202.html
Sat Apr 03, 2010 8:49 am
Pedal is still stiff. Started about 5 days after i turned rotors and put OEM pads/sensors from IOS. Pedal goes in an inch, brakes work maybe 25%. Changed master cylinder, bled lines until perfectly clear fluid, has vacuum pressure, no leaks in lines, fluid level is fine, abs unit hasn't worked for a year, thinking stuck valve in the abs unit? maybe when i pushed the calipers back in it forced some fluid into the unit and pushed a valve shut? any ideas?
