BreedOfSpawn »
https://forums.nicoclub.com/breedofspawn-u42575.html
Tue Jul 04, 2006 9:34 pm
Alright here's the scoop... I drove the car again during the day it runs fine...
At night when i turn the lights on I see my idling jump from 700rpm to 500rpm and back up to 600 then back to 500 then back to 700 all while the car is in neutral with nothing happening to it...
During the day the idle still jumps around but not as statically as it does when the lights are on at night.
So anyways when i drive the initial take off is fine but once i come to a stop light and i downshift and work my way to 2nd gear... hit the clutch and break to bring the car to a stop at the light the car shuts off i see the rpms go from 2000 to 1500 to 1000 to 500 to 300 then ultimatly at 0 as the car shuts off... its almost setup perfectly to the point where i know if im using some of the juice in the car then it will shut off at every stop...
I've come to the conclusion that maybe the alternater, the timing or the voltage regulator are not functioning propperly it could be either 1 or 2 outta 3 or worst case senario 3 outta 3... So tomorrow im taking it to the shop to get a computer diagnostics scan done to it and also have the alternater tested.
Im still a n00b first time driving a standard car and deff first time experience with a nissan... Still own my old 98 Tiburon *scoffs*... automatic lol so if anyone has any recogmendations for me to also check out ill definetly bring them up when i speak to the mechanic thank you all for your help thus far.
