90SXSE KA24ET DREAMS »
https://forums.nicoclub.com/90sxse-ka24et-dreams-u32802.html
Tue Oct 04, 2005 7:54 pm
some of you know my problems and some of you know what i replaced so far.
here's what i replaced..
plugscapfuel pumpiacv/acc tried a different ecu what my car did.... it would sometimes start and idle like crap and stall.
now with the things i replaced those didn't fix the problems...
so i check and made sure i was at top dead center... once i checked i found out i wasn't there.
so i set it at top dead center... after that the car still didn't wanna run.
so an idea came across my head and having extra gas in a soup bottle... i decided to pull off the intake filter and spray gas up the intake tube.. Once i did that the car started right up and ran this time without acutally stalling and it stayed running... but the idle was probably like im guessing 1,200 or so the idle was pretty high.. I don't know becasue all the sudden now my tach doesn't work. : (
and plus when i got to run with spraying gas up the intake tube,,, while it was running, i was hearing a spark plug knock.
Now if i get it running again with spraying gas into the throttle should i turn the idle down??? and then let car run till its warmed up, and then from there get a timing light and time it???
doing that i should no longer have anymore problems, anyone argee??
thanks for reading this again.. but i think i'm getting closer.
can someone let me know where the timing should be on the crank pulley markings and for the disturbor timing, how much do i advance or retard it??? or should i just move it till its line up in the middle between advacne and retard???
thanks again for any help.
photo's may help me too if you have photo's.
