twisted99s10 »
https://forums.nicoclub.com/twisted99s10-u66955.html
Mon May 11, 2009 2:12 pm
i have an 89 s13 with a s1 rb25 swapped in. i have a walbro 255 with a z31 fuel filter. i have a front mount intercooler, and a 3 inch downpipe and straight back 3" exhaust.
at around 5000 rpm the engine breaks up and i get clouds of black smoke out the exhaust. so i know its not a fuel cut. this leads me to believe it is maf or ignition related. the timing is set to 15* off top dead center. the ignition chip, and all of the coil packs pass the ohm tests. the spark plugs are ngk iridiums with a 6 heat range, and gapped to .80. i cleaned the maf with some spray contact cleaner today, and it didnt make a difference. i adjusted the tps into place. .45 when closed 4.5 at WOT. no noticeable difference. i am out of ideas. if any one has any ideas on how to fix this so i can enjoy my rb swap i would be eternally grateful.
thank you so much in advance.
