rb250sx »
https://forums.nicoclub.com/rb250sx-u8777.html
Sat Apr 09, 2005 1:15 pm
Ok, i put the transmission back up for the third time today, after trying everything you guys have been saying to try except replacing the pilot bushing, it still wont go into gear when running. So now im going to drop it yet again and replace the pilot bushing. But before i do i want to make sure there is nothing else it could possibly be, here is a list of what i have done and some things i would like to rule out.
What I have done:
flipped clutch disk around (is currently in correct)bled the system several times (positive there is no more air in the system)adjusted the pedal (fork is moveing all the way, and adjusted to see if it was going too far as well)
Can i rule out?-clutch disk and pressure plate. I got these from JDM Parts Plus, they didnt give me the correct disk at first because they screwed up the order, but it was still a disk for a 300Z, just a little harsher, so i kept it because i didnt want to wait any longer. It is a 4 puck sprung ceramic clutch and i compared it to the old clutch, same diameter spline fits fine, the only difference that i was wondering would make a difference is on the old clutch there is a piece thats sticks out about a quarter inch on the flat side of the disk where the input shaft goes rather than being completely smooth. I dont think this would make a difference but let me know if you think it would otherwise. -Driveshaft. Sounds dumb, but could the yoke be going in too far causeing problems? it sits about an inch to an inch and a half out from the rear of the transmission, so it sits where it should be but i just want to rule this out.
I really cant think of anything else, i didnt think it was the pilot bushing before because it was the bushing that came with the engine, and it was a manual to begin with. It didnt look mushroomed and it sits about an 8th of an inch inside the lip of the flywheel.
If there is anything else anyone can think of please let me know, ive had this transmission down way too many times and im getting frustrated haha.
