S14-KOUKI-MONSTER »
https://forums.nicoclub.com/s14-kouki-monster-u39701.html
Sun Dec 03, 2006 11:41 am
What bushings did you replace? Sub-frame & differential? I've been contemplating boxing mine vs kazama/ tanabe replacements(for camber adjustability) for a while. However, I don't think that would solve your wheel hop issue. What kind of welder do you have? Obviously you'd have to remove the paint/rust. Personally, I'd do it this way. Use a die-grinder with a wire wheel attatchment. Make a template with cardboard, and trace it on to the piece of steel. Cut out steel with saw/torch. Grind/file to shape while checking progress to control arm several times. Tack weld into place a few spots. Weld in small sections to avoid warping/melting control arm. Wire wheel again. Paint/powdercoat.
