Still fuel gauge problems
vicsnatch1
Car: 1989 Nissan 240sx
Hi everyone, my fuel gauge still doesn't give me the correct fuel reading. The day before yesterday I changed the fuel sending unit thinking that it might of fixed the problem. I had previously changed the fuel pump, Walbro 255, and the fuel meter starts moving up and down, not working. I need help on fixing this fuel problem. Also the female and male connectors that are between the whole fuel assembly, the whole metal that holds the fuel sending unit and the fuel pump, has some sort of white grease or a kind of component. Do I need to remove that? I noticed that in my 240sx and the one from a junk yard. Can anyone help please? thanks!
sean58888
Car: 91 240sx coupe
the white grease is to proventing short,so dont wippe it off.have you or anyone before you mess with the whole gauge cluster?the needle might be pulled out before and didn't set it back in right.or maybe its the fuel level floater in the fuel tank by the pump is stuck or bent??
vicsnatch1
Im going to try removing the fuel gauge and replace it. Thanks for the response!
