Im iffy... with driveshaft related vibrations, in my expereince, will only get WORSE when you lift the wheels up...... Because theresnothing loaded to sort of prevent the vibration.....pdqwrx wrote:OK, what is radial force variation ? If you can explain it to me I will check for it....I just had the front rotors turned so either the machine that turned them was out of whack (Possible) or I bolted them to a warped or wobbly hub.
I have ran the car at speeds while on the lift and could not see or feel the vibration. So perhaps it only does it under load.
The vibration goes away when you let off the gas.
I am doing more looking today....
Thanks for everyones help.Scott
"Radial force variation is the amount of change in stiffness of the sidewall and footprint when a load is placed against the tire."pdqwrx wrote:OK, what is radial force variation ? If you can explain it to me I will check for it....
)elwesso wrote:Most chain tire places like discount tire and such have the appropriate balacing machines..... The Hunter 9700 is the industry standard among tire places that sell expensive tires.... Ma and Pa may not have a hunter 9700, however all you have to do is ask.....
The thing that concerns me is that it goes away under decelleration (or letting off the gas)... thats not characteristic of tires.
What about a wheel bearing?? htat would certainly make sense, kinda.
This sounds like a common U-joint problem in older cars. I went through a lot of U-joints in my '69 Camaro. When they started going bad the vibration was only at certain power levels, or as you let off or put on the power.pdqwrx wrote:I have ran the car at speeds while on the lift and could not see or feel the vibration. So perhaps it only does it under load.
I'd still say drive shaft. When you neutralled it, it should have made a difference if transmission related.pdqwrx wrote:I just read part of my post from earlier and I didn't get one detail right....The vibration stays the same regardless of throttle. I can be accelerating or deceleratoring and still feel it. I also feel it with the transmission in neutral. That is what I meant to say.....Well i just mounted one new rotor and am about to mount the other (I went with the Cryo treated power slots) and then a test drive.
Now, my tire guy rotated the tires front to back and remounted the tires that WERE on the front (On back now) inside out to help with a camber related tire wera issue up front. And the vibration stayed exactly the same. I have turned the rotors and the vibration is exactly the same. I replaced the center bearing on the drive shaft and the vibration is exactly the same...... I am starting to see a trend here! perhaps I should look at the transmission?
