Joe »
https://forums.nicoclub.com/joe-u4941.html
Mon Apr 05, 2004 8:44 am
im still leaning twords timing, my idle was WAY off while my timing was screwed up (were talking 1500 fully warm). you need to check that long before you go trying to diagnose anything else, mostly because that actually effects greatly how the engine runs.
if you have an igniter you can use one of the wires comming off of it I BELIVE, if not you need to remove the coil pack cover and use an inductive timing light on the #1 cylinder wire (i THINK its the big white one, but i could be wrong, try all of them) the #1 cylinder is closest to the radiator.
and mack is right about the vacuum leak, even a small one can cause weird idle problems like that.
remember, unless you have professional tools, always start with the easiest and most basic things first.
