Postby
nik.. »
https://forums.nicoclub.com/nik-u125777.htmlTue Mar 17, 2009 7:18 am
if i will install stilen hi flow cats with the oem exhaust does it fit perfect?and second am i gonna have a problem with L sensor & check light is gonna be on?
Postby
aris_unlimited »
https://forums.nicoclub.com/aris-unlimited-u92534.htmlTue Mar 17, 2009 8:08 am
I think the hi-flow cats should fit ok on an oem exhaust. You will get a check engine light though. The way to fix that is to put a spacer between the O2 sensor and piping. If you do a little searching there should be some write-ups on it, suggesting how to space the O2 sensor.
Postby
aris_unlimited »
https://forums.nicoclub.com/aris-unlimited-u92534.htmlTue Mar 17, 2009 11:59 am
From what I have gathered all brands of hi-flow cats will show a check engine light when installed. Because there is more exhaust gas getting to the O2 sensor then it is programmed to recieve.
