Well, Suspension Techniques springs are presumably designed to be used with OE shocks so I don't see how the GR-2s would be a problem. I wouldn't run something like RSR Race springs on 'em, but the Suspension Techniques spring rates aren't anywhere near as stiff as the RSR.Red coupe wrote:Even if you dont get coilovers straight off GR-2's are supposed to be 15% stiffer then stock...thats weak. they are ment as a replacement. No sence in "upgrading" to a stock replacement man...
You miss my point...sure you can run close to stock spring rates on close to stock shocks, but why pay a few hundred dollars to replace functioning (I see no promblem buying a gr-2 or what ever to replace a dead stock strut) suspension with a thats barely different...BadMojo wrote:Well, Suspension Techniques springs are presumably designed to be used with OE shocks so I don't see how the GR-2s would be a problem. I wouldn't run something like RSR Race springs on 'em, but the Suspension Techniques spring rates aren't anywhere near as stiff as the RSR.
Forgot to mention...the Eibach Sportlines are for S14. Thanks to 240guyNY for reminding me.steaminhotryce wrote:Here's a close up...still in great condition. The owner told me they were installed for about a year and a half. Let's just say 2 years.
Cars are not supported by the shock....The shock is not only damaged by the lower range of motion but also by the extra work it takes to control a stiffer spring.steaminhotryce wrote:TO: drifters2it_sideways
If your car have excessive bouncing, then MOST LIKELY the shocks are blown. This is because stock shocks aren't really meant to go too low (with lowering springs). Having lowering springs on stock shocks would require them to work harder. You are bouncing because shocks are blown and the front is now supported by the RS*R lowering springs only.
I agree with what you said about the shocks working harder with stiffer springs in addition to my comment, but I don't think I said anywhere in there that the car is supported by the shocks.Red coupe wrote:Cars are not supported by the shock....The shock is not only damaged by the lower range of motion but also by the extra work it takes to control a stiffer spring.
:edit no offence ment just wanted to correct something I noticed...
steaminhotryce wrote:I agree with what you said about the shocks working harder with stiffer springs in addition to my comment, but I don't think I said anywhere in there that the car is supported by the shocks.
lol sorry I know what you mean though, just saw that and ocd made me post...ill stop nowsteaminhotryce wrote:You are bouncing because shocks are blown and the front is now supported by the RS*R lowering springs only.
Just out of curiousity,where do AGX's fall compared to stock(within their range of adjustment)?blake@tirerack wrote:GR-2's are designed to be 10 to 15% (depending on application) stiffer than O.E.
