C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Mon Mar 28, 2005 2:57 am
Clutch pedal stiffness is affected by the overall leverage in the system. The lever arm ratio of the pedal to teh master cylnder, the ratio betwen the mc and slave cylinder, the clutch actuation arm between the slave cylinder and the throwout bearing and sleev, and finally the leverage of the splines on the flywheel vs the spring rate of the flywheel itself. The only way to change it is to change one of these factors. A stiffer pressure plate will obviously add pedal stiffness. Changing the fulcrum of the splines on the pressure plate is a potential method but would likley need to be addressed on the manufacturer's end. Changing the pedal or clutch lever arm on the bellhousing are probably not reasonably viable options. You might try experimenting with different diameter clutch master cylinders and slave cylinders if there are any compatible units that would bolt up and offer a different size(akin to using a 300ZX Brake MC with 300ZX brakes). The ACT does use a stiffer plate, but it offsets this by allowing more leverage in the pressure plate as well. This way you end up with a stock-like pedal stiffness. You are probably just used to the stiffer feel. Given some time, you'll adjust. Most prefer a lighter pedal since it is much easier to modulate. You certainly want some resistance, but too much can make driving uncomfortable. Also, ending up with a similar pedal stiffness means the load on all the factory parts will be similar. So you don't end up with excess wear to the throwout bearing or the master and slave cylinders.
