I saw some STP ps fluid at Target. Will that work?elwesso wrote:BTW you use ATF for the PS fluid.
Not as well as Mobil 1 ATF. Look for a SnapOn shop that has the Sun ATF exchange machine and get it flushed. Will require one gallon of ATF.xmateo wrote:I saw some STP ps fluid at Target. Will that work?
Since you've already got ATF in there, just use good Dexron ATF. You will probably be replacing your pump soon anyway so don't waste money on Mobil1 until you replace the pump and fix the leak.xmateo wrote:I saw some STP ps fluid at Target. Will that work?
No, You have to look closely at the back of the belt - I know its not the best picture. It is cracked and now has a chunk (small) missing out of it. I can't figure out why the shop would replace 2 belts and not the 3rd one. The ps belt doesn't look too difficult to get to (compared to the others).maxnix wrote:Looks like a new (OEM?) belt, but did they check or replace the idler bearings? If they seize, even new belts fail. Show us the break where it failed.
You might want to upgrade your technicians.
Or call your mechanic and make his lazy *ss get over there and drive it to his shop to replace the belt!Jesda wrote:If the PS belt isnt connected to anything else on the J30, go ahead and drive it to your mechanic. Do some weightlifting first.
I'm not sure If I dare drive it. See that lose hose/pipe in my first pic? I have now idea where it came from or what it connects to.Jesda wrote:If the PS belt isnt connected to anything else on the J30, go ahead and drive it to your mechanic. Do some weightlifting first.
Oh, with the brass reducer end? Looks like some kind of vacuum line.xmateo wrote:I'm not sure If I dare drive it. See that lose hose/pipe in my first pic? I have now idea where it came from or what it connects to.
Forgot to mention that the belt did not break, it just came off.maxnix wrote:Looks like a new (OEM?) belt, but did they check or replace the idler bearings? If they seize, even new belts fail. Show us the break where it failed.
I recall a loud squeal about 20 mins earlier when I cranked the wheel hard as I backed out of a parking lot.Q451990 wrote:... did you noticed any squealing or unusual noises before your failure. Heath
What is Z32?maxnix wrote:Take it to a shop specialzing in Z32. Having a Consult I is an indication how competent they may be.
BBB, eh, is it worth your time? Might help someone else, but BBB never reports specifics to inquiring potential customers, just number of complaints.
