timmyk »
https://forums.nicoclub.com/timmyk-u130530.html
Fri Jul 17, 2009 11:00 pm
my brake booster blew before i did the motor swap, so i put in a new one during swap and now the pedal is really really stiff, cant even get it down to the floor...brake light is on in the dash [for e-brake and e-brake is off]...wheels off the ground and are hard to spin...
the rod has been twisted all the way back so theres no resititance
and another thing i noticed when i turned over the car, im reading 0 vac with foot off the throttle, and i believe it should be 20 vac, but when i put on the throttle it jumps to 20 vac then to 0 psi...
so,
1. what can i try/check for my brake booster?2. whats with my vac?
im assuming its the same problem cause the booster runs off vacuum...im finding this really strange because yesterday i was reading 20 psi at idle and now this has happened
i have searched and only come up with two possible things:
vacuum leak somewhere? - i did a boost leak test prior to start up and booster install and fixed all leaks, although my bov is still leaking under throttle and will be swapped tommorrow
or
a caliper pin has siezed some where...not sure how to check for this but i will poke around tommorrow..
basically im looking for your thoughts and any more suggestions
and if it helps this is on a 96 240sx s14, and when the brake booster blew i was drifting around a turn then started to spin and was applying the brakes fairly hard, then they just went soft, then really stiff
another thing my buddy was convinced that there is no air in the system and doesnt need to be bled,...
sorry for the novel, thanks for any help
