Stiff Brake Pedal 2000 Q45 (Failed Brake Booster)
lamsv
Driving to lunch this morning, I noticed my brake pedal was abnormally stiff. Caught me off guard, as if I only had 50% of my available braking power. I read the FSM which lead me to doing the suggested brake booster trouble shooting test. With the engine off, the pedal does not get incrementally harder to depress. It is stiff from the first pump. With the engine running, the pedal feels the same as with the engine off. Also, pressing the pedal with almost all my might (which I have to do to keep the car from rolling in car at a stop) at idle, the engine sputters and almost dies. This definitely leads me to think it is a vacuum leak.
I took a look at the vacuum line(s) that run from the intake manifold to the brake booster. The line that runs from the manifold to the intermediate metal tube on the firewall looked to be very brittle and possibly cracked at the end where it connects to the intake manifold. Upon removal, it was indeed cracked. I'm not sure it was it cracked before I took it off as it took some muscle to remove it. Either way, that line has to be replaced.
Where do I find this line? I can't find it on any Infiniti parts stores. This line has a built in check valve. Can I temporarily install a vacuum line that does not have this check valve until I can locate an OEM line?
Thanks for any help in advance!
-Seth
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
No, you must have that check valve for safe operation!
Did you call IoS? www.infinitipartsusa.com
Q451990
Ditto on Infiniti of Scottsdale. Do you hvae enough slack in that hose to cut the cracked part off and stretch the hose in place as a temporary fix until you get the replacement part? As Brian said, the check valve is very important... without it you'd loose vacuum at certain RPMs and you would also be pushing a blast of unmetered air into the intake evey time you pressed your brake pedal - causing engine performance (choke down) issues.
Heath
lamsv
I just got off the phone with infinitpartsusa (Infiniti of Scottsdale). They don't have the parts in stock, but can get them in a couple days. $19.90 a piece.
I did not have enough hose to cut and stretch to fit. The hose was extremely brittle for the first 4-5".
yodawill2000
Car: 94 Infiniti J30
and a short piece of fresh hose. :bigthumb:
lamsv
I might have to hold the order and give the DIY a try instead. I did see that you can add in your own check valve. Make it cheaper to fix if this happens again.
lamsv
Quick update.
While I wait for my new vacuum lines, I used a 3/8" line I had lying around from a past project. With no check valve, the brake pedal feel did not improve with this new line. Interestingly enough, at idle with the pedal firmly pressed, the motor surges really bad. It feels as if the engine is under load and wants to stall. I am almost certain my brake booster is bad. It must have a leak, causing the engine to see a vacuum leak and wanting to stall out.
I will be buying a new brake booster and hopefully installing it next week. Will update once that is completed.
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
Hook up a vacuum gauge to it and see if it holds vacuum and also press the pedal.
Q451990
lamsv wrote:Quick update.
Did this engine condition happen after you replaced the hose and deleted the check valve? If so, that's what I was talking about in my earlier post. Your booster is pushing air back into the engine when you press the brake... since that air isn't metered by the air flow sensor, the car doesn't know to compensate for it...
lamsv
There is a check valve in the system. $2 from the True Value.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
What is the condition of the brake fluid? Maintenance history?
lamsv
Fluid looks great. I replaced it when I got the car a year ago. Checked all calipers and none are sticking. The hard pedal feel is more than likely resulting from no assist from the booster.
Q451990
Did the engine issue start after you swapped the hose?
Booster failure is very rare...
lamsv
Engine issue started the morning when I realized the pedal was super stiff. I recently had a coil go bad that I haven't replaced. I thought the surging idle was related to the coil. But, after swapping in the new coil, the surging idle still persisted with a new hose and check valve.
Yes. Booster failure is rare, but not unheard off. At this point, if it isn't the booster, what else could it be? Brakes work perfectly fine, just takes a strong leg to get them to work. But, just driving around my block, car stops just fine.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Surging could be a combination of contaminated IAC valve and failed coilpack(s).
lamsv
I am throwing no CEL's after swapping the coil pack. Could bet he IAC, but it hasn't thrown a code. I will check that though.
But, with the nipple on the intake manifold for the brake booster plugged, my idle is perfect.
It is a bit late, as I've ordered a booster.... but is there an o-ring between the brake master cylinder and the brake booster? I don't know why I didn't think of it, but I had an o-ring fail on my old Tahoe between the booster and M/S. It caused these same symptoms.
Q451990
lamsv wrote:Yes. Booster failure is rare, but not unheard off.
Nearly unheard of though... I think in 15 years of very active internet activity I've heard of one failure on a Q - or any Nissan product for that matter. Doesn't mean it can't happen though... I've had one of the few brake pedal switch failures that I've heard of too.
I would install the new OEM hose and checkvalve first, and see if that fixes it in the hopes that you can return that brake booster.
I don't think there's an o-ring on the master cylinder that could fail and cause this... there's a test in the FSM for the booster that involves checking the piston length coming out of the brake booster. Shows some diagrams of the master cylinder as well...
http://www.nicoclub.com/FSM/
Good luck!
Heath
lamsv
I took a look at the test in the FSM. I am going to give it a whirl if the OEM lines don't fix the problem.
Thanks for the help! Hopefully, I don't become the lone Q45 owner with a bad brake booster. It would just be m luck. ;)
-Seth
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
I also only remember one failure of the brake booster. Cannot recall if it was a G50 or FGY33.
lamsv
Another update small update. Was able to throw on the OEM vacuum lines this afternoon. It did fix the surging of the engine at idle with the brake pedal depressed. It did not fix the stiff brake pedal.
Next, will replace the brake booster. Will update when that is done.
lamsv
3 hours, beat up hands, and more cuss words than I care to admit too... the end result being a replaced brake booster. Which, did fix the problem. Looks like I had that 1 in a million chance of a brake booster going bad.
End result: new brake booster, brake power and feel back to normal.
Q451990
I'm glad you got it fixed! I bet that is a bear of a swap...
:bigthumb: :bigthumb:
Heath
lamsv
Bear of a swap is right! Doable by a shade tree mechanic, as long as you have extreme, and I mean EXTREME, patience.
Q-ZILLA
Car: 1995 Infiniti Q45t
Rear Mount Turbo
R.S. Enthalpy Tuned on
Dynojet-5000lb roller
453hp/453lbft
2008 Nissan Armada
2009 G37 Convertible - SOLD
2004 Cad. Escalade POS - RIP
I just lost my booster as well; 238k miles... Guess that's a long enough lifespan for a car part. Went through everything else first to narrow the problem, but it's definately the booster. Bought a new MC to compliment the new booster. Now I get to spend the upcoming weekend bustin' knuckles.
lamsv
I wish I could give you some hints... but I can't. Just lots of patience.
Q-ZILLA
Rear Mount Turbo
453hp/453lbft
2008 Nissan Armada
Definately bad booster; running fine again, but not a fun repair, too much upside down. Already blew my back out earlier in the week...
Q451990
Glad you got it fixed! Back pain is no fun. I have a herniated disc that's bad enough the doctor said "wow... have you seen your MRI!?" on my first visit...
Heath
Q-ZILLA
Rear Mount Turbo
453hp/453lbft
2008 Nissan Armada
Yeah, I know the feeling, mine keeps slipping, pinching the nerve. Just slipped it out again last night cleaning out the dust from my blower motor, intermittent functioning; cleaned it out and works fine, but my back reminded me it's still not healed from the booster.
ebmorgan
Car: 2002 Infiniti Q45 Sport
I used to come here YEARS ago...like early 2000's when I ran NWMaxima.com. My account was gone, so I re-registered so I could say thanks for this thread. I had this exact problem with my 2002 Q45 (sputtering engine, hard brake pedal) tonight. The brake booster vacuum hose was crystalized and snapped off the inlet on the manifold. I pulled the broken bit off and put the line back on. Works again! Now I just got to order a proper replacement.
Thanks again! Yay Internet! :D
Q451990
I'm glad we could help!
:welcome: back to NICO and don't be a stranger!
Heath
