DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Sun Sep 10, 2006 8:27 am
OH... yeah im very sorry guy. i did read what you wrote, but its such a common problem it was worth double checking.
but when i read your new post, i can clearly see that you've found it, sorry i missed it previously.
you probably have them unplugged already, but i can answer.
now, what i thought you were asking before is how you remove the wires from the black connector. But what i gather you are asking, and correct me if im wrong, but you cant get them unplugged at all, as in you can't pull the black connector off of the red injector plug.
the poster before me is mistaken i believe. i have a 92, 93, 95, and a 96 KA and they dont have this mentioned connector. i've seen these on domestics all the time, but what this person is refering to is the connection that is on the coolant temp sensor. you wont be finding any metal wires here.
so, at the risk of sounding stupid, im gonna answer the question i think you are trying to ask, about unplugging injectors.
its gonna see so stupid its trivial, so i honestly assume that you already know what im telling you, but you just want someone to back you up before you break something.
on the back side of the injector connections, the black piece youre talking about, there is a button. you can feel it because there are grooves cut in it for your finger to be able to grab on to, like the edges of a quarter. you need to push this, i guess as hard as you can. it will make a clicking noise once it is disengaged. thats not guarenteed thoguh, because i have one that doesnt, but the other 11 do.
i can say that some are a *****. i used a large pair of needle nose pliers once to disengage it. you squeeze on the front and the back of it, but obviously you dont wanna break it.
so try some pliers on it. can you remove any of them? i squeezed pretty damn hard and they didnt break, but beware. i feel bad about being less than helpful before, and now i know what you are asking. you cant test the injectors without having the connectors pulled.... my bad.
lemme know how it goes, because there is a button on the back that will click when its disengaged. you'll feel it. plus they are always hard to pull the first time, it will be easy everytime here on.
