3-Z-CARS »
https://forums.nicoclub.com/3-z-cars-u213862.html
Wed Jan 02, 2013 8:09 pm
Thanks for the info. I got to looking around and there is this small threaded stud with a locking nut on the bottom side. It looks like something you can adjust so I loosened the nut, turned the threaded stud, clockwise a turn or so and then tightened the nut on the bottom side and now the throttle butterfly, for lack of a better name, is not sticking. I believe that this also changed/increased my idle rpm, so I'm going to find out what the idle rpm is supposed to be and then maybe play with it a little more. I sprayed the springs with some lubricant called Tr- Flow, something I've used on my nitro R/C helis, and everything is a lot smoother. I didn't see any PVC valve in the way.
Thanks again for the info! :-)
