sticky tb-searched
nismojunkie
hey everyone. i cleaned my Tb a few days ago and now it sticks really bad. when i start from a stop i have to be carefull with the gas pedal or it will not open the tb and will stall or it will just let loose and my car will jump. i used carb cleaner to spray it out, then i wiped it out with a rag. i have disconected the cable, so i know it is in the tb, i sprayed the springs with wd40, and no difference. another thing, i tried to adjust the idle and broke off the idle adjustment screw and the corner piece it sits in. as far as i can tell, this hasnt made any difference, it still idles good most of the time. but i have run out of ideas to fix it, please help.
chasse
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
I have the same problem. My Dad tells me to put grease on the springs and other stuff on the side of the TB. Havn't gotten around to it yet. If you try it let me know
nismojunkie
i tried putting a very thin layer of motor oil in the tb where the plate touches the wall, but it didtn help any, ill try the grease on the springs.
nismojunkie
ok, i put 10w30 oil on the springs on teh side of it and it seemed like it was somewhat easier to pull, but wheni was driving it was worse. now when it is out of gear ti wont idle and just stalls on me. so tomorow morning i am gona swap it for another tb i have that i didnt clean and hopefully i cant scew that up. i have no idea what i did to make it do this.
2_Liter_Turbo
That's quite wierd. I am going to take a look at mine to see if I can fix it. If I accomplish that I'll let you know.
nismojunkie
i put on the spare tb this morning, took me a little less than an hour. but my car runs and drives fine now. i think it might have somethign to do with teh idle adjust crew being broke off, but it didnt seem to be any lower than the good tb, i dotn know. but i got it fixed, thankfully. good luck on yours elnegro, when you find out , let me know.
chasse
