navysnail »
https://forums.nicoclub.com/navysnail-u13430.html
Mon Sep 20, 2004 10:39 am
you do it without the engine running
as for the a/c, make sure the clutch on the compressor is engaging when you turn it on, that sounds like the most likely problem since it works well when it does work, if the clutch doesnt engage when you hit the button, tap the front with a hammer after the button is pressed and see if that gets it going
