Newcastle82 »
https://forums.nicoclub.com/newcastle82-u13870.html
Mon Aug 23, 2004 6:22 pm
Had the same problem about six months ago.
Starter problems killed my car on the side of the road and I had to have it towed. Coincidentally (so it seemed) my hydraulic system died right after the guy dropped my car off in my driveway. I had almost zero clutch pressure to the pedal, and I bled forever to make -maybe- half an inch of headway.
It ended being not only my slave, but the master, too. Change them as soon as you can.
And do remember too, that when you bleed the clutch hydraulic lines, it's a little different than bleeding brakes. Bleeding brakes you depress the pedal 5-6 times and hold while someone cracks your bleeders. Bleeding a clutch, however, simply depress the pedal once, twice, and hold - then crack the bleeder. There isn't that much line running between master and slave as there is with a 4 whl disc brake system.
Good luck =)~
