This is my 2004 Nissan Sentra SE-R Specv.
Mods List:
Engine:
Mega squirt version 2 standalone
JWT race c1 cams
JWT valve springs
JWT Balance shaft removal kit
WRP Crank pully
Custom 1 7/8 header with 3 inch collector
Custom 3 inch exaust with dump before rear tire.
port and polished head
port and polished intake manifold
Custom intake manifold spacers
upper intake custom made for 3.5vq tb
custom 3 inch maf housing
custom cold air intake thru headlight 4inch tube to 3 inch
battery relocated to right bumper
ac removed
power steering removed
alternator moved to where ac copressor was for big tube header
idler pulley put where alternator was
fuse box and relay box moved to bumper
rev auto tourqe dampner
FIR solid motor mounts
half size radiator and 12inch flex lite fan
ka24 thermostate for lower temps
10w30 castrol oil
k&n filter
Transmission:
stock trans
stock clutch and flywheel
axxition sts
FIR Shifter solid bushings
bg syncroshift
Suspension and wheels:
TDM IMPORTS custom coilovers with 8k front 12k rear
2jracing anit lift kit.
hard race control arm bushings
hard race rear subframe bushings
energy suspension sway bar end link bushings
weld drag lites 15x8 in front with M&H 23x8.5x15
15x3.5 in the rear with M&H 24x4x15
80mm 1/2 diameter arp wheel studs front and rear
1/4 wheel spacers in the front
Interior:
fully gutted interior. kirky racing seats with 5 point race harness.
autometer pillar pod with water temp, oil pressure, volts.
raptor shift light
radio and stereo equipment removed.
custom pod with aem wideband and switch for fan up top where radio use to be
white face gauge cluster, made by import intelligance first person to have for 04
all ac and heat equipment removed.
pcm was moved to interior for easier access
Exterior:
shaved rear door handles
vis carbon fiber trunk
evo carbon fiber hood
custom flaps on rear bumper for air flow
black paint but soon to be all one shade
I.C.E.
who needs ice when your flying.
WEIGHT REDUCTION
all unnessasary wiring has been removed carpet padding, and sound detting has been removed rear windows have been bolted up so no window regulators what every extra metal the car doesnt need has came off, no bumper supports in the front or rear, both carbon fiber trunk and hood, sunroof has been removed and plexiglass has been installed. spare tire well has been cut out. all evap stuff has been removed. rear deck lid and door crash bars been removed. removed rear spare tire well and installed thin layer of sheet metal. removed rear deck where speakers go. removed all evap system. probley some more stuff just cant think of it right now.
FUTURE PLANS
get more weight out the car.
remove the gas tank and put in a fuel cell
Competition clutch
Fidenza flywheel
uprev engine managment
paint job
and go faster.
