MaineExport »
https://forums.nicoclub.com/maineexport-u157.html
Sun Aug 18, 2002 5:49 pm
First of all... don't expect the best quality sound reproduction with a band-pass box.... especially not a Jensen. I'm not saying it's junk, but they're priced cheaper for a reason. But, since it was designed to be a band-pass enclosure...DO NOT USE IT AS AN OPEN AIR box!!!!!!! The band-pass design basically makes the speaker more efficient... so it is a lesser speaker that is made to sound better with proper tuning to the volume of air in front and behind the speaker.... and porting. If you remove the plexi-glass you totally negate the purpose of that setup, and compromise the sound "quality". Don't do it... it will sound worse!
