tigersharkdude »
https://forums.nicoclub.com/tigersharkdude-u59453.html
Wed Jan 13, 2010 5:45 pm
I'm looking into replaceing the speakers...I have the factory non-bose head unit...I know from crutchfield they are 6.5 front and rear....My car has the seperate components in the front doors....
If you have tweeters in your doors, either you DO have OEM bose or someone added tweeteres
Can someone tell the exact size for replacing the front speakers....I would like to replace the exact size...What size tweeter do i need to order to drop right in? 6.5"
The rears i assume just a standard 6.5" .... same as the front. standard 6.5"
Do the door panels need to be removed for replacement? YES
I see from in the truck the hardware for mounting speakers comes from the top...Can i just pop the covers off the speakers to remove hardware and speakers? answer posted above
I'm unsure of correct speakers to buy to run with stock head unit...I dont want to buy a speaker that needs to be pushed with an amp... just buy some replacement speakers, not a component set unless you plan on running an amp
Can the factory speaker wire be reused with aftermarket speakers?? ( with the correct ends put on)... YES
With the factory wireing how do you know whats + and -...For wireing new speakers? when you unplug the speakers, one side will be + and one will be -, I.E. there will/should be labels on the speaker
If you have any problems, just post some pics or something. I troll the forums every day. I will try and help you
