Loop »
https://forums.nicoclub.com/loop-u80201.html
Sat May 17, 2008 9:12 pm
Nissan vehicles hub bore size is 66.1
Yes, you need a hubcentric ring. You don't want to load/rely on your bolts/lugs to center your wheel. Also it has other downsides to not using one. Make sure you get the right size for the outer diameter to fit properly in your wheel.
