stereo wiring help...
Post all your Nissan electronics, car audio and stereo questions here!
niemczykj
Car: 1992 240sx fastback, 1986 Z31 Turbo
i did search but couldnt find an answer... so i wired up my cd player, and it turns on, but has no sound.... im wondering if i connected the speaker wires wrong... does anyone know which wire is which color? i can try to redo it and see if it works,,,
ncs14
Car: 1995 240x se
i had the same problem on my s14. had power but no sound. if i remember on mine there was a amplifier power that had to have power for the speakers to work. I cant remember what forum i searched to figure it out. But I dont know if the same goes for the S13. I had an S13 a couple of years ago and I had a lot of problems getting my aftermarket to function. good luck man!
qsiguy
Car: 1994 Infiniti Q45 Turbo
Was the stock system a Bose? If so that opens up a whole new can of worms. It's not a direct swap to an aftermarket radio.
niemczykj
i have the problem fixed... everything works fine now thanks
qsiguy
Well now that's not acceptable! If you start a help thread you have to give us the solution! What ended up being the problem, we won't laugh....much.
VAcutieNthatJ30
Car: 1994 Infiniti J30
Hi..... I am having the exact same problem. How did you fix it?
Thanks
