stereo
flyboy367
Car: 95 maxima se 5spd
where did you guys run your power wires?
also my antenna doesnt work i got the replacement part and followed the instructions but the mast wont come out. i took off the nut and grommet am i missing something?
feel free to post pics of your setup
allensteiner
Car: 1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
stereo...you mean head unit or amp? i have a sony deck wired to the original harness and a home made short antenna - didn't like he look of the stock mast.
flyboy367
the amp wiring, head unit is all in.
i actually put a switch on my antenea lead so i can make it work when i want it. 90% of the time i listed to mp3 anyway. my head unit is an alpine for just mp3 or radio. i just need to fix it because its stuck up and i cant get it apart.
davskins97
Car: 2001 Nissan Maxima SE
This article should tell you everything you need to know...
http://www.vqpower.com/v2/read..._id=9
flyboy367
thanks, little to late though lol. i drilled a hole between the clutch master and brake booster and ran my 2 gauge thru it. although that would be a good spot for 8 gauge for anyone running a small setup. i have 2 amps for a total max of 1800 watts so i overkill all my connections to make sure it gets power but also wont transform my car into a match head. i still cant figure out the damn antenna though. ill try taking out the unit even though its stuck up. worst case im painting it anyway ill shave the thing and install an in car one.
