stereo
vczar1
Car: 1997 Infiniti J30 130K
If i replace the speakers and a stereo, do i still need to use a Scosche OEA-4 adapter or do i just need a wire harness, and if you replaced your front speakers what size worked for you? are BOSE amps on the speakers only or is there another one? Thanks for the info
gr8scott72
Car: 1994 Infiniti J30t
vczar1 wrote:If i replace the speakers and a stereo, do i still need to use a Scosche OEA-4 adapter or do i just need a wire harness
If you are using speakers and stereo then just a wiring harness for the stereo and you can use the bose speaker wires for each of the speakers.
vczar1 wrote:and if you replaced your front speakers what size worked for you?
4". I took the bose speaker enclosure and put my 4" speaker in there and sealed it all up air tight with caulk. Cute little ported box.
vczar1 wrote:are BOSE amps on the speakers only or is there another one? Thanks for the info
The front speakers don't have the amps attached to the speakers. The amps for the front speakers are inside the speaker box inside the front doors. I just took the amps and wiring out when I put my speakers in the box.
Like so:
Wu1x
Car: Infinti J30
Sory;but thhat is the wrong way to do that, those bose enclosures are tuned for harminics when u change the speakers you alter the harmonics thus deteriorating the quality of sound. if u remove the grill from your door the easy way to do it is get a set of 6x8's and a spare set of 6x8 grills and screw them directly to the pannel infinity has securedthem well enough to limit rattle,if u dissable the bose enclosure and mount the rear half of it it will stope the draft from entering the car. Use the wires in the door if u wanna get balzy u cna do 6x9's I have them and I am adding 4" mids above to make some more mid.
sorry don't have a cool picture but the bose enclosure alters the sound in a negative way.
gr8scott72
Wu1x wrote:Sory;but thhat is the wrong way to do that, those bose enclosures are tuned for harminics when u change the speakers you alter the harmonics thus deteriorating the quality of sound. if u remove the grill from your door the easy way to do it is get a set of 6x8's and a spare set of 6x8 grills and screw them directly to the pannel infinity has securedthem well enough to limit rattle,if u dissable the bose enclosure and mount the rear half of it it will stope the draft from entering the car. Use the wires in the door if u wanna get balzy u cna do 6x9's I have them and I am adding 4" mids above to make some more mid.
Mine sounds great so, whatever.
