jjcuff1 »
https://forums.nicoclub.com/jjcuff1-u191473.html
Sat Nov 19, 2011 10:10 am
Another update to my stereo saga to help all others in search of the dreaded weak BOSE units. I had the 8 speaker setup. I swapped out Infinity 2 ohms front and rear. Alpine mono MRP500 amp and 3 different subs.
1: Noobs: Start with the sub first I did speakers might be waste of money and upgraded speakers in 2 ohms will require a 4 channel. So sub and at least volume of stock speakers will be more matched to the sub output. I did the speakers first and sounded great but have to crank up at least to 5-6 or 7 on ipod just to hear volume. They are crystal clear but with no power and probably high crossover in bose they sound like all treble no mid bass. I addition once I did the speakers the stock sub volume disappeared like it was removed. I think the volume sent to speakers and crossover in sub cut the rear out.
2: So I added
Pionner shallow mount in rear deck with alpine mrp-500. Speaker defintely hit and had pressure but in no way had any SQ as a free air and any bass as REAL boomy and rattled the crap out of rear deck. In addition the EQ of the Bose had the output levels all over the place. meaning one song would sound good on radio and next one would require twice the volume and half the bass or it distorted or had no bass. just all over the place. Amp also was lke at 10% gain. any more and rattle box.
I considered MS-8 Cleansweep and 4 channel but all along knew let me play with bass some more to see.
3: I kept sub in and tried a pioneer shallow mount in pioneer shallow box. it was good but broke up and wasnt ideal for trunk needs to be under a seat and lots of volume to hear through the seat.
4: Then tried a standard cubed ported 10" box with Diamond D1 sub. MUCH better it was boomy and loud and no rattle in the rear deck, well a few notes rattled the deck or shook the rear pass through. This was a 4 ohm dual coil into a 2 ohm setup gain was like half way. It was good for most genres, but still boomy and not as present on hard rock metal at normal volumes. It definitely worked though and sure maybe d3 or other mid level subs would be clearer but the SQ of the ported box did not me or the trunk location. It ran better with the rear pass through open. Plus the box took up more space then I wanted
5: Finally tried a Kicker L3 square box setup at 4ohm. It was a taller box but shallower then the d10 setup and fit flush against the rear seat and next to the amp facing back to trunk. Immediate improvement! At same amp settings at D10 just plugged in and at all volumes had snappy tight bass on rap or rock or radio. Even ipod levels were clearer with little more bass. The box and speaker definitely can handle the power of the amp and probably can give it more thump. With the rear pass through closed and at 7-9 volume I heard no rattle and no distortion and bass was much tighter even the boomier bass sound great and the rock had its snare and mid levels hittings too! I was surprised that this box which is more sealed then ported or tuned better and the speaker can sound great through the trunk fully enclosed
SO Lesson learned: 300-500watt RMS in trunk is best best
Start with sub first, and forgo the rear deck route just simple box to start
-can alwasy get custom mount later if needed
- rear deck setup WILL require amped front speakers and crossovers to elimnate vibration rattle and well as better match the volumes levels of all speakers, the sound stage was messed up with the free air and just mono amp. expensive setup with probably minimal bass compared to cheaper box route
-If you replace the fronts just go 4 channel, one for doors and tweeters and just get mid drivers and good tweeter
- pull off bose output and just tweak through 4 channel amp
- Sure can do crossover or DSP processor but that always sounded over sampled and pretty sound stage on dash but end of day power, loud, force, booom etc just comes from amp, watts, sub in trunk and for fraction of price you will probably be happy with 4ch amp, mono, amp, box, new compenents
