stereo stupidness
ray666
Car: '92 240 sr powered tuned with a neo
okay so the previous owner butchered the stereo system in my s13. he had wired it to the battery and didn't use and the stock stuff. my question is since i'm not electronically inclinded, what brand cd player out there mates with the stock plug? or am i forced to take to someone?
moulton712
Car: coupe, hatch, both s13s
no aftermarket radio mates up to the stock plug. what you need to do is buy an adapter harness if you are using the stock plug. other than that you can hard wire that in.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
if the harness is hacked...either wire whatever harness of the unit you buy or get a stock harness and reattached the wires.
Its not to hard either way, as long as you can see colors.
Or fork out like $400 and some one will get your car playing music hopefully headunit included in that price..
Two Fowty
Car: 1990 240sx hatch, 1989 240sx hatch
when you buy an aftermarket stereo, it comes with a harness that plugs into it, with all the wires leading off of it, which is what you connect to the wires coming off of the car-end of the wiring harness. If the car-end of the wiring harness is cut, then you gotta find a new one and cut that area off and connect it in, then things should go smoothly. Don't take it to someone, it's such a loss of money. If anything, ask personal friends and stuff for help.
moulton712
it's not $400. more like $50-85
Shabbernigdo
moulton712 wrote:it's not $400. more like $50-85
to wire up a radio to a hacked up harnes?
the lowest ive seen was like 100$ and thats if u buy a radio from them and let them install it.
ray666
yeah looks like i'll be doing the wiring haha. the wiring is all hacked up. i'll try to find a buddy to help me out, thanks guys.
Steve Lloyd
where in florida are you??? If you're not to far, I could help you out............
Broadfield
Car: 1992 240sx
At my store I charge $65 labor to install a radio into a vehicle with a chopped harness. However, my labor rate is the lowest of about any place I know of...... especially in Illinois.
ray666
thats a really good cost for labor. i live just outside of pensacola . i've been driving around without music for a year now so you can imagine it bothering me. folks in the area are really proud of their work. i'll call around. hopefully i don't get the shaft.
Steve Lloyd
ray666 wrote:thats a really good cost for labor. i live just outside of pensacola . i've been driving around without music for a year now so you can imagine it bothering me. folks in the area are really proud of their work. i'll call around. hopefully i don't get the shaft.
little to far for me to go to help, but it's really not to hard to do. There are a few custom shops over that way that are really good, and fairly reasonable on prices. Been a few years since I've been that way, but they should be easy to find.........
ray666
i'll def. give a go myself. it doesn't seem that bad.
zerepdivad
Car: '90 240sx . '02 Lexus IS300
buy a multimeter, learn how to use it, and it will be very simple to figure out.
ray666
my dads got one. he could've done it for me but he's on his way to afganistan.
Azrial
Car: 93 240sx vert, 1990 pignose hatchback roller
If you search for other radio topics one of them will have the 240sx stock wiring diagram. I forget the website but it will tell you what the wires are based off of your stock harness wiring. I used it when I had radio issues when I bought my vert. Then I couldn't test the radio while it was in my lap because they use the bracket as a ground. It's not very hard to figure out the wiring for the stereo but it helps a whole bunch if you know what wire is what. I am pretty sure this was it http://www.installdr.com/Insta....html click on the pdf for your year vehicle scroll down.
here is the s13 one the format is pin, what wire it is, in car color, aftermarket adapter wire color. A +12 Volt Ignition Wire Blue RedB Do Not UseC Ground Wire do not connect to this wire, see instructionsD Do Not UseE +12 Volt Battery Wire Red w/ Black Stripe YellowF Right Front Speaker (+) Brown GrayG Left Front Speaker (+) Blue w/ White Stripe WhiteH Power Antenna Turn On BlueI Right Front Speaker (-) Brown w/ White Stripe Gray w/ Black StripeJ Left Front Speaker (-) Blue w/ Yellow Stripe White w/ Black StripeK Right Rear Speaker (+) Blue PurpleL Left Rear Speaker (+) Red GreenM Factory Amp Turn On Lite Green Blue Power Antenna WireN Right Rear Speaker (-) Pink Purple w/ Black StripeO Left Rear Speaker (-) Dark Green Green w/ Black StripeP Do Not Use
ray666
sweet! this helps out a lot. thx
Azrial
No problem that's why we have a forum. So we can get help. Good luck with fixing it take some pics let us know when you get done.
ray666
yeah i'll try to get some pics of what i'm dealing with
breadbox
89 Koop
84 720 4x4KC
You got a soldering iron and shrink tubing?
ray666
yeah i got all that. i know i'm definetly gonna need that stuff
