myriad46 wrote:Just ordered a JVC KW-HDR81BT head unit to replace the stock stereo. The instructions indicate that the factory harness does not include a ground connection, and that the wire from the stereo's harness will need to be connected to the cars ground in some way. Has anyone found a good place behind the stereo to do this? Any convenient bolts within reach? Should I run a wire somewhere else in the front of the car to get a solid ground? Fuse block? Just trying to get the right supplies together before I tear that dash apart. Thanks for any help or suggestions.
i have not replaced the headunit, but i imagine its like anything else.
go to radio shack and grab one (if you can) if not, just buy the little package of them
http://www.radioshack.com/product/index ... =CT2032231
crimp the ground wire into the red section, and take the head-unit mounting screw and put it through the hole, and install your head unit. that grounds it.
